Activity Forums Adobe After Effects GTX 780 in AE FYI (windows)
  • GTX 780 in AE FYI (windows)
    Posted by Nevin Styre on June 6, 2013 at 10:49 pm
    I received my PNY GTX 780 a couple days ago and just wanted to inform that after adding it to the raytracer_supported_cards.txt it does indeed work fine in after effects for raytracing. I’ve only had time to test 1 raytrace render so far, but it rendered in 40% less time than my factory overclocked GTX 570. Also premiere mercury engine works after adding the 780 to the cuda_supported_cards.txt .
    Todd Kopriva replied 13 years ago 6 Members · 7 Replies
  • 7 Replies
  • Roland R. kahlenberg
    June 6, 2013 at 11:40 pm
    Thanks for sharing Nevin. Please provide updates as and when necessary.
    Cheers
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE
  • Nevin Styre
    June 6, 2013 at 11:55 pm
    I will definitely try to. I’ll aim for a few more tests before and after the CC update for raytracing, as well I can do some element 3d tests.
  • John Cuevas
    June 7, 2013 at 1:08 am
    There’s a benchmark test here. I’d be really interested in seeing how it did on that test, if you don’t mind.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Zeno Costa
    June 7, 2013 at 5:31 am
    Raytracing support in AE for the GTX 780 and not the GTX Titan? Whaaat?
    The GTX 780 and GTX Titan are both GK110! Adobe, please fix this!
  • Nevin Styre
    June 7, 2013 at 6:23 am
    4:43 Render time
    Running Win 7 on an i7 920 @2.8GHz (non D0 version) with 16GB DDR3 with the 780.
  • Steven Mullins
    June 20, 2013 at 4:53 am
    Any news on GTX 780 compatibility? Thanks!
    Steven Mullins
    Motion Designer
    EchoOut Motion Design
    https://www.echoout.com
  • Todd Kopriva
    September 9, 2013 at 11:14 pm
    The GTX TITAN, GTX 780, and several other cards have been added to the list of cards that After Effects will use for GPU acceleration of the ray-traced 3D renderer in the After Effects CC (12.1) update, coming in October.
    See this page for details:
    https://adobe.ly/AE_CC_12dot1_details
    After Effects team blog
