GT240M and Boris
Posted by Theo Van laar on December 15, 2009 at 9:36 pmDoes anyone knows how well the Nvidia Geforce GT240M and Boris FX/Graffitti/RED are working together?
Theo Van laar replied 16 years, 9 months ago 2 Members · 11 Replies -
Matt Mullen
December 16, 2009 at 4:05 pmTheo,
Do you own the card now? You can run the trial version of Graffiti to test it.
I don’t have this card to test with but looking at the card specs I think it should work fine for you.
Running the trial and testing is always the best way to make sure.
Theo Van laar
December 16, 2009 at 4:40 pmHi Matthew,
No it’s the other way around. I have already the software but I’m thinking of getting a laptop with this videocard…
Theo
Matt Mullen
December 16, 2009 at 5:46 pmTheo,
The card has sufficient memory and support for Open GL. The card should work with Graffiti.
-Matt
Theo Van laar
December 20, 2009 at 5:04 pmMatthew,
I have another related question. Boris FX etc will not work as a plugin for Vigas 64bits. However, when I would install the 32bits version of Vegas on a 64bits Windows PC (I assume that’s possible?), will Boris FX etc be recognized by this 32 bits Vegas and be functional?
Theo
Matt Mullen
December 22, 2009 at 4:46 pmNo problem Theo.
I hit you on both boards to make sure you didn’t miss it.
If you have any more questions don’t hesitate to ask!
-Matt
Theo Van laar
December 27, 2009 at 12:30 amThanks Matthew. Then I have another question for you. I bought the new computer and Boris runs indeed fantastic! Except that I have problems with activating my copy of Boris FX 9.3.2 and Graffity 5.3.2. Boris tells me that my registrationnumber is not valid. This problem occurs with Vegas Pro 8.0c and 9.0c
So what is the right procedure to activate Boris FX and Graffitty on the new computer?
Thanks for your help!
Theo
Matt Mullen
December 27, 2009 at 10:42 pmTheo,
The screen should be giving you a Unique Product ID.
The easiest way to resolve this is for you to directly send me these numbers.
Please send them to mattm@borisfx.com and I’ll respond Monday with what you need to unlock the software.
-Matt
