Activity Forums Adobe After Effects growing vines and transparency
  • growing vines and transparency
    Posted by Heather Crank on October 10, 2007 at 11:38 pm
    Hello All,
    I’m going to be animating some vines (as in Jayse’s tutorial). The issue I’m having (and forgive me if this belongs in another section I thought I’d start here) is the vines the client wants are at a 30% transparency. So when I cut up the vines into sections, the over lap between a vine and say a leaf that I’ve separated is visible as a hard white line. Is there any way to avoid this without hours of fiddling with individual pixel transparencies?
    Thank you!
    H
    Heather Crank replied 18 years, 10 months ago 5 Members · 5 Replies
  • Filip Vandueren
    October 11, 2007 at 1:00 am
    Can’t you create it in a precomp at full opacity, and lower the opacity of the precomp layer ?
  • Kevin Camp
    October 11, 2007 at 1:06 am
    if the leaves will also be at 30%, just work at 100%, then bring that ‘vine and leaf’ comp into another comp and decrease the opacity of the vine and leaf comp…
    but i suppose the leaves are not at 30%… maybe they are 60%. it’s been a while since i’ve seen the tutorial, but i think i would just create everything at 100%. once that’s done, precomp just the vine part. now precomp all the leaves in another precomp. duplicate the vine precomp and move it above the leaves comp, and set the leaves comp to use the vine comp as a track matte. set the opacities as needed.
    i think taht should work… if there is a bit of a gap between the leaves and vine, try putting simpler choker on the track matte vine to see if you can get rid of it.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Jerzy Drozda jr
    October 11, 2007 at 1:44 am
    Just to let you know guys… I’m preparing a special CustomEffect, that will allow complex animation like the one you’ve mentioned to be as simple to do as possible, by animating everything for you. Well… maybe not everything, but it will keep the amount of keyframes and the time needed to produce such complex effect at minimum.
    I’ve thought it up especially for “growing elements” but it can be used in different animations.
    It’s not ready yet, but I think it will be soon.
    Oh… and as usual, it will probably be totally free.
    How does that sound, huh? 🙂
    maltaannon.com – Free After Effects Video Tutorials and more
  • Lifetypo
    October 11, 2007 at 2:09 am
    Maltaannon you are seriously a genius . your last few presets have been for cs3 so im working on getting that . but your seriously the MAN!!! thanks for everything
  • Heather Crank
    October 11, 2007 at 3:26 am
    Thanks everyone, I really appreciate the info. I’m going to try all the suggestions and see what works…
    Thank you again!
    H
