Activity › Forums › Boris FX Particle Illusion › Growing Vines
  • Elvis Deane
    December 14, 2005 at 4:45 am
    The July 2003 has the vines emitter, in the Eki Halkka folder. Make sure that you turn on Don’t Erase in the Project Settings. Otherwise, it’ll just look like a bunch of blips moving around.
    You can edit the shapes of the leaves by editing the Size over Life of the bottom particle type.
    Elvis Deane!
    The particleIllusion FAQ
    particleIllusion Resources and tutorial CD
    Astounding Adventures
  • Adrian anthony Vasquez salteiro
    December 14, 2005 at 6:24 am
    Ok! i found the folder.. but I only get to see the leaves.. the vines are not visible..
    I went to the proyect settings.. and I checked the box that said Dont Erase.. What could be wrong?
    PD: Thanks in advance
  • Alan Lorence
    December 14, 2005 at 3:22 pm
    They both work for me — make the emitter line longer and let the project go longer than 120 frames. You’ll see the vines.
    Alan.
    wondertouch
    December 14, 2005 at 10:44 pm
    Hey Thanks bro!.. now I figred out the purpose of that “dont erase” checkbox! heheh .. REally ingenius emitter!!
  • Aharon Rabinowitz
    December 15, 2005 at 3:57 am
    you won;t see anything until you actually hit “Play.” ANd if you start later in the timeline, it will only draw from that frame forward in time.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
