Activity › Forums › Maxon Cinema 4D › growing sweep nurb … how to add more movement?
  • Brian Jones
    January 21, 2006 at 1:51 am
    Often discussed. A couple of possiblities – Path Deformer, DiSplineDeformer there are other ways. There was SweetSweep but that crashes in 9.5 (and I’m not sure it would do what you wnat – I don’t remember). With the first two, they deform an object along a spline so you would need to grow it out to the length you want then move it along the spline after it is the right length.
  • Bender
    January 21, 2006 at 2:55 am
    cheers! path deformer worked great!
    florian
