Activity Forums Adobe After Effects Growing strokes effect – seems basic
  • Growing strokes effect – seems basic
    Posted by Juli Sandoval on August 9, 2016 at 9:05 pm
    Hello, i’ve been a lot of time trying to get an effect that makes strokes alpha channel strokes to grow, like the one in iggy azalea’s video (sorry could’nt find a better refrerence.)
    https://www.youtube.com/watch?v=iS1g8G_njx8
    seems pretty basic but i just can’t find it
    thanks a lot 🙂
    Kevin Camp replied 10 years, 1 month ago 3 Members · 3 Replies
  • Sean Dunn
    August 9, 2016 at 9:22 pm
    Videocopilot did a similar tutorial,
    https://www.videocopilot.net/tutorials/stroke_fx/
    Does this help/what you were thinking?
  • Juli Sandoval
    August 10, 2016 at 12:38 am
    sort off, not exactly what i was thinking, but i can make it with a thousand layers that way 🙂
  • Kevin Camp
    August 10, 2016 at 8:49 pm
    you might be able to get close with vegas (the effect).
    add it to a keyed layer, set the stroke to image contours, channel to ‘alpha’, blending mode to ‘under’ and set the various opacities and hardness to 1. then set the width and color as needed.
    duplicate vegas and set the color for that instance, and repeat that process as needed. as it expands out, you may need to adjust the segments.
    if you just had two colors for the ‘strokes’, then you could just animate the width of the first vegas effect, and then add a loopOut() expression and I think it would work. with more than that, you’ll need to explore how to animate it.
    —- edit —
    i had mentioned adjusting the segments to try and fix an issue with the ‘hardness’ of the stroke, but that doesn’t do it.. you might have to use a levels or curves effect to tighten up the alpha in between the vegas effects.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
