Growing Hair with Gradient Map
I have a texture, which has an animated gradient map slowly growing across a the face of a letter. As the gradient map is animated, the colors change and it works fine.
I’m attempting to add hair into the mix. My thought was that I could use the same gradient map and apply it to the Length parameter and have the hair be revealed with the same mask. I’m having difficulty getting the gradient map to align as it does with the texture. It seems like it would just align the same way, but it appears to be way off.
Any ideas?
