Activity › Forums › Apple Motion › Growing A Shape Vertically
  • Growing A Shape Vertically
    Posted by Steve Crow on July 12, 2009 at 9:35 pm
    This isn’t a question, it’s an answer – to my own question. I found the solution just now and it was staring me in the face the whole time. The issue was how to make a shape, like a vertical bar grow higher or lower.
    The answer is:
    1. Set the Y value of the anchor point so that it is at the bottom of the shape instead of its default location in the center.
    2. Next, under “Scale” animate the Y value up and down as needed to grow and shrink the shape vertically.
    You wouldn’t believe the ugly workarounds I was using to create this effect.
    Ariane Fisher replied 17 years, 2 months ago 2 Members · 1 Reply
  • Ariane Fisher
    July 13, 2009 at 3:06 pm
    You can also create the rectangle at the final size you want, and then animate a crop or rectangle mask to reveal it.
