Activity Forums Adobe After Effects growing a plant
  • growing a plant
    Posted by Jon Hornbacher on May 14, 2008 at 4:01 pm
    We’re working on a project with a vector graphic of a stylized vine — doing the typical growing out of stems and leaves.
    We used the Stroke effect, which works well for this kind of work. But Stroke doesn’t seem to enlarge with the rest of the rasterized vector graphic. When I zoom in on the move with the camera, the stroke stays the same width rather than staying relative to the graphic.
    My questions are: is there a way around this Stroke limitation? and Is there a better way to do the plant vines growing effect?
    –jon–
    Jon Hornbacher
    Tilt Media
    Clinton Inselmann replied 17 years, 8 months ago 5 Members · 5 Replies
  • Jon Agnew
    May 14, 2008 at 4:09 pm
    did you try precomposing the growing vines?
  • John M. rice
    May 14, 2008 at 4:21 pm
    This is the tutorial for you:
    https://library.creativecow.net/articles/hansen_jaysen/growing.php
    I just used it the other day. a bit long but it covers the topic well.
  • Darby Edelen
    May 14, 2008 at 6:26 pm
    [Jon Hornbacher] “But Stroke doesn’t seem to enlarge with the rest of the rasterized vector graphic. When I zoom in on the move with the camera, the stroke stays the same width rather than staying relative to the graphic. “
    This will happen if the vector layer is set to continuously rasterize. Another option might be doing the stroke on a solid above the layer, parenting the solid with the stroke applied to the vector layer and using the solid as a track matte.
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
  • Jon Hornbacher
    May 14, 2008 at 7:53 pm
    Thanks for the responses! Very helpful tutorial too.
    But for zooming WAY in on a vector file with a Stroke effect, Darby nailed it:
    [Darby Edelen]“Another option might be doing the stroke on a solid above the layer, parenting the solid with the stroke applied to the vector layer and using the solid as a track matte.”
    Everything is rasterized EXCEPT for the solid. When the camera zooms in on the vector art, the solid layer’s Stroke effect pixelates, but you still end up with a perfectly rasterized graphic:
    https://buffalonas.com/tiltmedia/links/STROKE_RASTER.mov
    Thanks again.
    –jon–
    Jon Hornbacher
    Tilt Media
  • Clinton Inselmann
    January 9, 2009 at 5:17 pm
    I’m not sure I under stand this work-around.
    I used Jayse Hansen growing vines tutorial and every thing works fine… EXCEPT when I scale or zoom or even toggle the continuously rasterize off and on. The stroke for the write on effect doesn’t stay in the right place or scale correctly.
    Any help/explanation would be greatly appreciated.
