Activity › Forums › Adobe After Effects › Grow/Expand a matte?
Posted by Aaron Neitz on December 17, 2007 at 9:37 pmIn Shake I can take a layer that’s a mask, and use DialateErode to grow it. Essentially the opposite action that Matte Choker does in After Effects.
So can I grow the edges of a matte in After Effects? I’m drawing a blank.
Rafael Folk replied 12 years, 10 months ago 4 Members · 7 Replies -
I.a. B.
December 17, 2007 at 9:57 pmunder the menu for the mask there should be a thing that says “mask expansion”
Aaron Neitz
December 17, 2007 at 10:05 pmRight on that. But I’m not drawing masks, I’m using a black&white video image as a “track matte: alpha layer”. That’s what I need to grow.
I.a. B.
December 17, 2007 at 10:12 pmoh sorry, you said mask at one point so that tripped me up.
hmm i’ll have to try some things out. someone will probably think of something better by the time i figure a decent way out.
Aaron Neitz
December 17, 2007 at 10:29 pmI can kinda get Matte Choker to expand it a little, but it gets awfully noisy.
i just rendered it out in Shake and brought it into AE. But there must be a way to do this otherwise.
Darby Edelen
December 17, 2007 at 10:39 pmSimple Choker usually works well for choking/expanding something after it has been matted. You can also look at Minimax under the Channel effects to run a minimum/maximum operation on the RGB or Alpha channels.
Darby Edelen
Designer
Left Coast Digital
Santa Cruz, CA
