Activity Forums Apple Final Cut Pro Legacy grouping the clips
  • grouping the clips
    Posted by Shuaib Veettil on August 10, 2009 at 8:53 am
    Hi.. Anybody have idea how to group multiple video clips put into one group to one click and select or move all together?. Not one video clip and synced audio clips, but several adjacent video clips together or audio clips together.
    Thanks pals
    Shuaib Veettil replied 17 years ago 4 Members · 4 Replies
  • Victor Perez
    August 10, 2009 at 3:00 pm
    You could try nesting the Video & or Audio Clips.
    select adjacent clips then press ‘Option C’ and name your new group (Sequence)
    The clips will be nested in a group which can be moved around together. in order to edit them you will have to double click on the nest to open the group of clips.
    hope that helps,
    Victor
  • John Fishback
    August 10, 2009 at 3:13 pm
    Nest them and move the nest? AFAIK you can’t group in FCP like you can in some other programs (like Pro Tools).
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Nick Meyers
    August 10, 2009 at 3:16 pm
    you cant “link” video clips the way you can audio clips, if that’s what you’re hoping.
    the only ways in FCP are to:
    a. make a multiclip of the clips (as in multi-cam style editing)
    b. nest the clips (they behave, and appear as one clip
    c. do it manually:
    lasso all the clips and work on them together, to move them,
    use the “multi_ iteration of your tools SHift-B will blade al, Shift+T will select all tracks forward.
    use the “Group” tool to select multiple edit points for trimming.
    what is it you want to do??
    nick
  • Shuaib Veettil
    August 11, 2009 at 7:13 am
    Thanks victor, john and nick.. Pity isnt it? such an efficient application neglect this type of features which the editors some times hungry for it as im now. Im bit not comfortable nesting practice. Reason is many changes i expect from the client as the live edit they did filled with mistakes. My option as follows. I did select all on the time line, choose all track forward tool, press command to deselect from the forward where i click so the clips backward selected and im able to move on. Thanks anyways for your help.
