Activity Forums Maxon Cinema 4D Grouping Splines???
  • Grouping Splines???
    Posted by Lars Wikstrom on September 6, 2005 at 4:26 am
    I forgot this from a tutorial a long time ago. I created 1 Bezier spline. Kind of like looking down a jet engine. I copied that spline and shrank it down. Now, I’m trying to group the splines together so I can add the extrude to extrude the jet enging. I am have a hard time grouping them. Still using version 7
    Thanks.
    -Lars
    Lars Wikstrom replied 21 years ago 2 Members · 2 Replies
  • Brian Jones
    September 6, 2005 at 10:01 pm
    I think in 7 it was: make the splines editable, drop them in a null, do a Functions/Connect and drop the resulting spline into your Extrude.
    It’s the drop them in a null part I am unsure of, I think that was the v7 way (it’s been a while). In 8 and 9 you just select both the splines in the OM and do a Functions/Connect. In 7 since you can’t select more than one thing at a time I believe the null was the solution…
  • Lars Wikstrom
    September 7, 2005 at 4:05 am
    It sounds like the best thing is to upgrade. I don’t use it that often anymore so I would hate to spend hundreds of $$$ on it.
    thanks,
    -Lars
