Activity Forums VEGAS Pro Grouping 50 clips / Grouping selection
  • Grouping 50 clips / Grouping selection
    Posted by Jill Simpson on April 7, 2009 at 1:44 am
    To group (or ungroup) a bunch of clips, I ctrl-click each one, then press G (or U). If some clips/events are very tiny, there is a danger of not seeing them, and missing them.
    Simply selecting a length of the timeline (shift-arrow or click-drag), then pressing G — does not work.
    Is there some magic button I could add to the second method that would make it work?
    Is there another solution to the problem?
    Adam Rose esq. replied 17 years, 5 months ago 3 Members · 2 Replies
  • Mike Kujbida
    April 7, 2009 at 2:40 am
    I just showed this technique earlier today for some students so I know that it works.
    Click the first one, shift-click the last one, press G or U and you’re done.
    I find it helpful to drop a marker at the start and end of a large section like this to make sure I get all clips.
  • Adam Rose esq.
    April 7, 2009 at 8:47 am
    I just press D twice, drag across the selection, then press D again twice to return to the regular cursor, and off you go – to U or G etc
