Activity › Forums › Maxon Cinema 4D › Grouped objects
Grouped objects
Posted by Adam Guy on September 4, 2006 at 3:16 pmHow do you resize all objects together once you have grouped them, cheers
Adam Guy replied 20 years ago 3 Members · 6 Replies -
Simon Carlson-thies
September 4, 2006 at 7:59 pmThe easiest way is if you have grouped them in a null object select the null right click and say select children deselect the null, grab the scale tool and have fun…
Simon Carlson-Thies,
Digital Light Graphics And Animation -
Adam Trachtenberg
September 4, 2006 at 9:09 pm[Simon Carlson-Thies] “The easiest way is if you have grouped them in a null object select the null right click and say select children deselect the null, grab the scale tool and have fun…”
The easiest way is to scale the null–no need to select the children.
Simon Carlson-thies
September 4, 2006 at 9:53 pmYou’re right, I was thinking in the context of editable objects…. and way out of the scope of the question….
Adam Guy
September 5, 2006 at 7:40 pmThank you for your feedback. I’m probably doing something wrong! I have tried all suggestions but can only use the right scale tool, which doesn
Adam Trachtenberg
September 6, 2006 at 4:20 am[plastic] “Thank you for your feedback. I’m probably doing something wrong! I have tried all suggestions but can only use the right scale tool, which doesn
Adam Guy
September 14, 2006 at 1:56 pmThank you for your help. I have made all my objects editable but still can’t seem to scale them all together. Is there a way I can post a screengrab? many thanks
