Activity Forums Avid Media Composer Grouped clips cutting to timeline
  • Grouped clips cutting to timeline
    Posted by Aoife Carey on June 8, 2012 at 3:30 pm
    Using Avid Media Composer 5. We’re trying to cut grouped clips into the timeline. We have 2 audio sources, 1 video source grouped. Is it possible when you cut a selection into the timeline to take BOTH audio sources?
    Aoife
    Aoife Carey replied 14 years, 2 months ago 3 Members · 5 Replies
  • Shane Ross
    June 8, 2012 at 10:13 pm
    If they both are in the grouped clip, then yes.
    Shane
    Little Frog Post
  • Andrew Mckee
    June 9, 2012 at 5:03 pm
    Possibly you want to use AutoSync rather than group (which is designed for multicamera editing) to combine the video with the 2 audio sources? Then you will have a subclip containing all the clips on different tracks (including the audio from the video clip if you select that option in the AutoSync dialogue).
    Andy
    Andrew McKee
    Editor/Colourist
    Avid Certified Instructor – MC6
    Apple Certified Trainer – FCPX
    Pixelwizard.net
    Futureworks.co.uk
  • Aoife Carey
    June 11, 2012 at 9:30 am
    Thanks Andrew! Will have a go at Autosyncing. Is it the same as Grouping clips in that you can toggle between the two?
    Aoife
  • Aoife Carey
    June 11, 2012 at 10:41 am
    Hi Andrew,
    I tried to autosync and while this will let me change between the audio tracks by right clicking on the audio in the timeline, it doesn’t allow me to bring all four audio tracks onto the timeline simultaneously. Is this a setting problem or are you simply not able to do this with AVID?
    Many Thanks,
    Aoife
  • Aoife Carey
    June 12, 2012 at 1:44 pm
    Hi Andrew,
    Apologies- I was a bit confused. The clips I’m working with were auto-synced and then grouped. I’ve tried cutting in a clip with the camera audio and then the same segment with the external audio, but they both seem to want to go to Audio tracks 1&2 and so overwrite each other. Could this be what the problem is?
    Aoife
