Activity Forums Maxon Cinema 4D group multiple ojbects under separate nulls?
  • group multiple ojbects under separate nulls?
    Posted by Sergio Juyak on February 28, 2013 at 10:24 pm
    I have a poly mesh that is broken up into individual polys (thanks to the guy who showed me how to do this!). I nowb need to group each of these polys under it’s own null. I did it once manually but I have to do it again an there are about 700. Is there any sort of way to select all of these and, instead of grouping them under one null, rather, have each poly parented under it’s own null?
    thanks
    Adam Trachtenberg replied 13 years, 6 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    March 1, 2013 at 5:16 pm
    I don’t know of any way to do that natively, but I’m sure that someone with a little scripting knowledge could write a script to do that. Unfortunately I’m scripting challenged so I can’t help in that regard.
    May I ask why you want each polygon to be in its own group?
