Activity Forums Avid Media Composer Group from autosequence
  • Group from autosequence
    Posted by Alessandro Cerquetti on February 2, 2014 at 4:41 pm
    Hi, i’m starting a job for Italian Tv.
    Source Camera:Canon C100
    for 4 camera
    video format 1080- 25p
    DNXHD 36 mb from avid media composer 6.2
    Audio:
    Running in tc clock sinc preset (same for all).
    Production will shooting for 6 month in this set up
    for syncronize all 4 camera and sound I use auto sequence TC preference.
    It’ all ok but:
    Result: a big timeline with many video-audio tracks and too black holes
    I need to make a group or subclip from timeline sincronized for to have better organizer .
    Can help me?
    Regard
    Alessandro
    Richard Sanchez replied 12 years, 7 months ago 3 Members · 5 Replies
  • Michael Phillips
    February 2, 2014 at 6:01 pm
    If they have common timecode, why not use group or multigroup? Or are you using autosequence to manually set sync references first? There is no function that takes a sequence such as this and creates a group/multigroup although it would be possible to engineer such a solution and is a great feature request that has come up many times before.
    Michael
  • Alessandro Cerquetti
    February 2, 2014 at 6:37 pm
    Hi Michael,
    yes my editor assistant make a auto sequence to manually set sync references firs for assemble all shooting daily.
    They shooting sometimes all together 4 camera or record and stop camera during the take, and then rec another time, result : many segment in timeline and gap.
    would be very helpful as a function of group from sequence,
    so no hopes?
    regard
  • Michael Phillips
    February 2, 2014 at 7:22 pm
    In the past I have created a dummy clip that I logged that encompassed the full range of clips I wanted to have in a single group clip, then included that when grouping based on common timecode. This way there is always a camera active while the other can be going on and off. Then I don’t display that once I set up the group. Maybe that will work for you?
    Michael
    February 2, 2014 at 8:20 pm
    how does it work?
    looks interesting..
    Alessandro
  • Richard Sanchez
    February 2, 2014 at 8:31 pm
    Sound like reality TV multi grouping. This is the basis by which most AEs I know would group that.
    https://viewfromthecuttingroomfloor.wordpress.com/2008/04/17/multigroups/
    However, that method in conjunction with this pages suggestion on add edits will probably be your best bet. At least it’s how I do it.
    https://willblanksblog.blogspot.com
    Richard Sanchez
    Los Angeles, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
