Activity Forums Avid Media Composer Group clips in Xpress Pro HD 5.5
  • Group clips in Xpress Pro HD 5.5
    Posted by Phil Byrd on September 4, 2006 at 6:01 pm
    August 17 post expressed concern that Express Pro HD 5.5 upgrade would gang only four group clip files instead of the much higher number available in earlier releases. I couldn’t determine if his post was addressing only the four-way multi cam display, which is in earlier releases, or a real loss from earlier versions.
    Is anyone using 5.5 with group clips or more than four in a group?
    Phillip Byrd
    Brandenburg Productions, Inc.
    Montclair, NJ USA
    Michael Hancock replied 19 years, 12 months ago 2 Members · 1 Reply
  • Michael Hancock
    September 4, 2006 at 6:23 pm
    I believe it’s 4 total in a group clip now, regardless of multicam editing. Before you could group many more, but now it’s been limited due to a coding oversight (according to some knowledgeable folks in the Avid forums). It’s supposed to be on the list to fix. There has been a workaround discovered–I haven’t tried it (don’t have to–don’t have 5.5 yet), but it’s worth a try.
    https://www.avid.com/exchange/forums/thread/133939.aspx
    See the 2nd to last post for the workaround. Seems like a bit of hassle, but at least it’s something to get you going.
    If you use Group Clips in large numbers as an integral part of your workflow, don’t upgrade until this is fixed, unless you need something provided in the upgrade that’s even more important.
    Those are my 2 cents.
    Mike.
