Activity › Forums › Sony Cameras › Ground Glass artifacts with Letus Extreme
  • Ground Glass artifacts with Letus Extreme
    Posted by Colby Gottert on April 30, 2009 at 3:42 am
    I have noticed that when using the Letus Extreme on the EX1 that I can see traces of the ground glass (even when it is vibrating) when I have the fixed lens set to a higher f-stop. For example, f8 leads to more artifacts than f4 and f 4 in not as clean as f1.8.
    I have put some video up on my blog:
    https://www.colbygottert.com
    Has anyone else noticed this?
    Jeff Regan replied 17 years, 5 months ago 2 Members · 1 Reply
  • Jeff Regan
    April 30, 2009 at 6:22 pm
    This is a well known limitation of most oscillating glass 35mm adapters. You don’t want to close down more than f5.6. Shutter speeds should be kept low as well.
    The Letus Ultimate can be stopped down as far as you want without seeing the ground glass because it spins vs. oscillates. However, even the Ultimate should not be used with shutter speeds higher than 1/500th.
    Jeff Regan
    Shooting Star Video
    http://www.ssv.com
