Activity › Forums › Boris FX Particle Illusion › Ground explosions
  • Evideom
    January 19, 2006 at 12:01 am
    Put your emitter on the screen, right click it anc choose circle or ellipse. That will give you the effect I think you are looking for, you will probably still have to mess around with some of the other functions to perfect the look. Zoom is also another setting to use.
  • Alan Lorence
    January 19, 2006 at 12:29 am
    Also, decrease the emission angle from 360 to 90 or less, then adjust the angle to 90 (for straight up).
    Alan.
