Activity › Forums › Boris FX Particle Illusion › Ground explosion
Ground explosion
Posted by Shadu on March 10, 2006 at 10:54 amAnyone know was made the ground explosion as see in the pro emitter eclectic 2 package?
I try to figure it out.
Shadu
Unzarjones replied 20 years, 6 months ago 3 Members · 3 Replies -
Alan Lorence
March 10, 2006 at 12:31 pmThe way to analyze an emitter is pretty simple. Start at the top of the hierarchy and select each property one at a time, and look at the graph. Any graph that is animated (has more than one data point) should be experimented with to see what it does to the overall effect.
Most of the “magic” happens in the particle type “over life” properties.
Also look at the particle shape images used for each particle type.
Alan.
wondertouch
