Activity › Forums › Adobe After Effects › GridIron X-Factor
  • GridIron X-Factor
    Posted by Bill Oneil on November 18, 2005 at 9:34 pm
    Has anyone had any success stealing processor power from another computer using X-Factor? (It’s Included with AE 6.5)
    I am entering into a difficult project that will need some extra speed so I plan to borrow from the dual core computer upstairs through the network. Any tips or success stories before I dive in? Thanks!
    Bill O’Neil
    https://chicagospots.com
    Bill Oneil replied 20 years, 10 months ago 4 Members · 4 Replies
  • Steve Roberts
    November 18, 2005 at 9:39 pm
    I haven’t tried Gridiron yet, but searching the COW on “gridiron” should bear fruit.
    Have you also tried using multiple instances of AE to render a still sequence on a dual-proc box? If you haven’t, look for the “How to run two AE apps at the same time etc.” thread below.
    Steve
  • Brothelowner
    November 18, 2005 at 11:02 pm
    Yes i have run the Grid-Iron X-Factor software before.
    It is fairly good, but the demo version is limited to 4 computers. The real version is quite pricey if I remember correctly.
    I cannot remember if it speeds up rendering…
    but it does speed up previews…
    When you do a Ram Preview in AE and the little green bars begin to fill up from the left of your work area, the other computers begin to fill up from the other end and in the middle etc until the work area is rendered, then it plays normally.
    It seems pretty useful, but 4 computers is a but limited.
    regards,
    BrothelOwner
  • Rhett Robinson
    November 18, 2005 at 11:14 pm
    To be honest, Although I liked the faster previews by sharing 2 other machines on a gigabit hub, I found Gridiron to be too problematic for daily use, and just use the good old fashioned (but extremely powerful) multiple machine render. I found Gridiron did speed up rendering, because AE does not have to re-render the “green areas” that it’s created a preview for
  • Bill Oneil
    November 19, 2005 at 12:23 am
    “…I just use the good old fashioned (but extremely powerful) multiple machine render…”
    How does a multiple machine render work? And how does it differ from GridIron? Thanks!
    Bill O’Neil
