Activity › Forums › Adobe After Effects › GridIron Nucleo Pro – Alternative Plugin for CS6?
Posted by Guy Smith on July 17, 2012 at 4:26 pmit seems this plugin does not work with 5.5 or cs6, which is a shame as it’s a very useful plugin to speed up AE. Is anyone using a different plugin in cs6 that does a similar job?
thankyouVictor Wolansky replied 13 years, 7 months ago 6 Members · 10 Replies -
Todd Kopriva
July 17, 2012 at 4:28 pmWhich features of Nucleo Pro are you trying to use that are not built into After Effects CS6?
product manager, professional video software
After Effects team blog
Premiere Pro team blog
Scott Carter
July 17, 2012 at 4:43 pmIf you prefer not to use the built in tools in AECS6 you can always use the BG_Render script. Works great.
https://aescripts.com/bg-renderer/
Todd Kopriva
July 17, 2012 at 5:08 pmBG Render is great, but it doesn’t do all that Nucleo Pro does/did.
One feature that After Effects CS6 has built in that is similar to a feature in Nucleo Pro is Cache Work Area In Background.
There are some resources about that feature and some related features here.
Also, you can now render After Effects compositions in the background with Adobe Media Encoder… which most people seem to miss.
Scott Carter
July 17, 2012 at 5:54 pmHi Todd,
Could you please point me to a link on background rendering with media encoder. I am one of those who has seemed to miss this. Thanks. -
Todd Kopriva
July 17, 2012 at 6:01 pmInformation on adding After Effects compositions to the AME encoding queue is here:
https://bit.ly/NyuAKq———————————————————————————————————
Kevin Camp
July 17, 2012 at 9:52 pmwhat would be really cool would be to add a comp to the ame queue straight from after effects… like a composition>add to media encoder queue. the queue itself could live in ae, so all the render settings and output module settings could be set there and the ae wold just send it to a background ame renderer.
actually, maybe the queue is the same, but there is a background render button that sends the jobs to ame….
i’ll find the after effects feature request page and make this suggestion….
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Scott Carter
July 17, 2012 at 10:24 pm^agreed. A background render button within AE would be a long overdue enhancement/necessity.
Guy Smith
July 18, 2012 at 5:30 pmyou know I suspected that might be the case, I guess it does render as fast as cs5 with the plugin. good info about the settings, I’ll test them all out, thankyou all
Jason Lyons
January 10, 2013 at 4:18 amAmen! Its nice to drag a comp straight into AME from AE but as you point out, but the user is not presented an option to select workspace instead or entire comp, unless you click on the preset hyperlink in AME, then wait and wait and wait for Dynamic server.
IMHO – Makes most since to add to queue as normal then click a little box saying send to AME… and off it goes to AME with all settings.
Victor Wolansky
January 16, 2013 at 2:32 pmThe render comp in the BG feature is cool, but not near the speed of Nucleo, and Nucleo was intelligent enough to start working at full speed at any moment you stopped doing something. Also was very fast to send the comps to the BG copies of AE, with multiprocessing ON in AE comps takes sometimes long time to be sent to the other instances of AE, also we still see ram caches to vanish after hitting stop on the ram playback even after not changing anything.. I was hopping Adobe buy this technology from them and integrate it on AE, we had a very sad time when figured it was discontinued.
