Activity Forums Adobe After Effects Expressions Grid with squares organic motion in Z space
  • Grid with squares organic motion in Z space
    Posted by Brad Hodgson on August 20, 2009 at 6:28 pm
    Hi all… can anyone help me with an expression? Should be fairly easy I’d think…
    I have a grid of 9 squares. I need an expression tied to a slider to make it easy for those 9 squares to float back and forth slowly in Z space randomly to provide an organic fluid motion, but then be able to originate back to their precise starting grid position via the slider.
    Does this make sense? Can anyone help me here?
    Thank you!
    Brad Hodgson
    Brad Hodgson replied 17 years, 1 month ago 3 Members · 4 Replies
  • Curious Turtle
    August 21, 2009 at 11:35 am
    Here you go. Adjust frequency as you want, and the amplitude is your slider.
    Just keyframe the slider back to 0 and you’re done.
    freq=1;
    amplitude=effect("Slider Control")("Slider");
    a=wiggle(freq,amplitude);
    [value[0],value[1],a[2]]
    Cheers,
    Ben
    Curious Turtle Pro Video
    Training | Editing | Support
  • Filip Vandueren
    August 21, 2009 at 11:45 am
    What you need is described in this tutorial:
    https://library.creativecow.net/articles/ebberts_dan/noise.php
    All you need to change is that instead of having amp=100;
    you should create an expression control slider and pickwhip to that instead of 100;
    Now you can keyframe the slider and you’re done.
  • Brad Hodgson
    August 21, 2009 at 3:24 pm
    Thank you, Ben!
    Brad Hodgson
  • Brad Hodgson
    Great. Thank you, Filip!
    Brad Hodgson
