Activity Forums Adobe After Effects Grey Wash?
  • Grey Wash?
    Posted by Ben Mcewan on November 15, 2008 at 11:33 am
    I’m sure this is a stupid problem, but I just can’t fix it…
    I’ve imported an uncompressed quicktime file into AE and completed all the required vfx. Then when I export, not matter WHAT format or compression options I use, theres this slight grey wash over the footage… I tried importing the source footage as other file types too, and still no luck =(
    Any ideas?
    Thanks heaps!
    – Ben McEwan
    Steve Lemonds replied 17 years, 9 months ago 3 Members · 2 Replies
  • Roland R. kahlenberg
    November 18, 2008 at 12:55 pm
    Haven’t had this happen b4. Perhaps you have some color adjustments going on that you forgot about. Try dropping an Adjustment Layer at the top of the stack and apply a colour adjustment tool to remove the unwanted effect.
    Cheers
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
  • Steve Lemonds
    November 19, 2008 at 4:11 am
    At the bottom of the project window…make sure you are set to 8bpc. If you are at 16 or 32 your color effects may be too much.
