Activity › Forums › Compression Techniques › grey screen when using ffmpegx to convert
Posted by Sascha Engel on July 11, 2011 at 5:18 pmHi,
I tried to convert MTS files in ffmpegX NTSC 29.97fps to .MOV PAL 25fps.
But I just get a grey screen, flickering with a little green.
What do I do wrong?Thanx.
Sascha
Craig Seeman replied 15 years, 1 month ago 2 Members · 3 Replies -
Craig Seeman
July 11, 2011 at 6:01 pm[Sascha Engel] “But I just get a grey screen, flickering with a little green.”
What is doing the “getting?”
Not all players can handle all codecs.
I’d suggest testing in VLC. -
Sascha Engel
July 11, 2011 at 6:07 pmNo, in every player I have on my system..including the VLC I get a flickering grey screen.
I do get a correct encoding if I do it with Toast, but it’s not de-interlacing.
I have all codecs installed for the ffmpegX, but it’s not giving me the right output for the MTS files.
Any idea what it can be? I did read that ffmpegx should be capable of handling MTS files.Sascha
Craig Seeman
July 11, 2011 at 6:24 pmI don’t see anything that points specifically to .mts output. Keep in mind HDV has very specific parameters. HDV can me an MPEG-2 Transport Stream but most MPEG-2 Transport Streams are not HDV.
It seems iFFmpeg has replaced ffmpegx but I’m not sure if it encodes to HDV either.
https://www.macupdate.com/app/mac/35846/iffmpegHDV is usually 25mbps, 4:2:0 color space and PAL or NTSC Long GOP depending on format.
