Grey outline Alpha Inverted Trackmatte
I need to create a black video with transparent text. So only the characters from the text are transparent so the underneath video can bleed through the letters.
For this I have an illustrator file with transparent background and white text.
I import this file into after effects. I use this file to Trackmatte option to cut through.However, when I use a black background I can see a grey outline of the text.
It looks like the track matte uses only the 100% white to cut through, the grey outline of the text remains white.
here an example :
Whats wrong here? how can i make the r and e disappear and only the white c remains visible?
