Activity › Forums › Apple Final Cut Pro Legacy › grey lines/blocks when exporting
  • grey lines/blocks when exporting
    Posted by Molly Snyder fink on May 16, 2014 at 9:02 pm
    I have been exporting from FCP and Quicktime player and getting grey blocks across the video or photo.
    I have older versions of things: FCP7, quicktime player 7.6.9 and my OS is 10.5.8 on a macbook pro laptop.
    My video however is Calibrated DVCProHD 720p60 Integer Little Endian (it was exported from FCP) and I put it back into FCP to do export or do export from QT player. Either way, I get the grey blocks/or lines.
    I’m not able to update to proappsqtcodecs because of my OS.
    Shane Ross replied 12 years, 4 months ago 2 Members · 3 Replies
  • Shane Ross
    May 16, 2014 at 10:06 pm
    [Molly Snyder Fink] “My video however is Calibrated DVCProHD 720p60 Integer Little Endian”
    Calibrated DVCPRO HD? You mean you are editing MXF native using the Calibrated software?
    Shane
    Little Frog Post
  • Molly Snyder fink
    May 16, 2014 at 10:20 pm
    unsure. I have a QT file with the settings I specified. I then bring into FCP and do export. and that is when the grey lines show up. hope that helps…
  • Shane Ross
    May 17, 2014 at 6:17 pm
    Try making a new sequence…ProRes settings. Copy and paste into that sequence…render. then export.
    Shane
    Little Frog Post
