Activity › Forums › Adobe Premiere Pro › Grey Diagonal Lines
Grey Diagonal Lines
Posted by James Niebauer on November 9, 2011 at 2:10 amThese lines are showing up.
So what’s this about? Anyway to get my footage back?
It just shows black in project monitor when played back.James Niebauer replied 14 years, 10 months ago 2 Members · 2 Replies -
Angelo Lorenzo
November 9, 2011 at 4:37 amThe footage isn’t offline, but you see it mostly with precomps that have been shrunk and the tail or head doesn’t exist so that part is shaded with the gray lines.
Did you try and import from a FCP project or an EDL? If that had timecode markers with the added hour as is sometimes normal, your in and out points may be far shifted in each clip beyond where actual footage is.
Angelo Lorenzo
https://filmsfor.us – Helping you sell your film online
Watch Steve Job’s Spirit Inside The iPhone 4SSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
James Niebauer
November 9, 2011 at 8:30 pmYes it was a FCP .XML import. The footage is from an HVX200. There is also T3i footage in there that does work that does not have the grey lines. It looks like the clip length is correct it just is off on what part of the clip shows… Is there anyway to correct this? I already tried adjusting the time code by subtracting an hour but to no avail.
Also if I preview the file in the preview monitor I can see it. If I drag the same clip to the timeline it has lines and goes black on the project monitor. But if I reimport the the same clip and put it to the timeline it does work. Even the HVX200 footage.
