Activity Forums Apple Final Cut Pro Legacy Gremlins with transcoding
  • Gremlins with transcoding
    Posted by Mark Huckle on June 9, 2009 at 6:02 pm
    Having successfully created a DVD for part one of a wedding vide project, I have run into problems transcoding the timeline from HD to SD. I’ve followed the same procedures as per usual and copied and pasted to SD timeline (having changed the settings). The first 4 and last 15 minutes are fine – the middle bit is stretched and zoomed in. I can’t think why. The only things I’ve done different is to have used more video and audio tracks than per usual and changed my setting on the video processing from 8 to floating 10 bit. What I want to avoid is re-editing the distorted part of the sequence. I’ve tried transcoding a number of times all with the same outcome. ANy one out there got any bright ideas? Your help would be most appreciated.
    David Roth weiss replied 17 years, 3 months ago 2 Members · 1 Reply
  • David Roth weiss
    June 9, 2009 at 6:10 pm
    Mark,
    You’re doing an extra and unnecessary step. There is no need to transcode from HD to SD when making an SD DVD. Encode HD to MPEG2 in Compressor, making sure to check the 16×9 checkbox in the Geometry tab, and you create a DVD that displays 16×9 on widescreen TVs and 4×3 letterboxed on 4×3 TVs.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
