Activity Forums Adobe After Effects greenscreen question
  • greenscreen question
    Posted by Accountclosed on August 6, 2007 at 7:13 am
    Hello. I plan on doing a play on the mac vs pc commericals, except instead of the pc, there will be 3 pcs.
    now i dont have enough greenscreen to shoot all 4 people at the same time. i was thinking of shooting them all one by one and compositing the shot together into a master shot (for the opening)
    however, i’m not sure if that will work. before i start experimenting, i was wondering if anyone had done this before. let me know if you can. thanks.
    Accountclosed replied 19 years, 1 month ago 4 Members · 4 Replies
  • Michael Duff
    August 6, 2007 at 7:57 am
    yeah, you can shoot each person separately and composite them together … just make sure your green screen covers as much of the talent as you want to key … ie.. foot to head if you want full body shots…
    then just follow normal greenscreen procedure …
    have a search around the COW and web for “garbage matte” “garbage mask” “green screen” “chromo key” “rotoscopin” …..and hopefully this will point you in the right direction … good luck
  • Georgi Zhekov
    August 6, 2007 at 10:26 am
    I’m sure that it will work,even if you shoot every person separtely and if you use the correct technique,no person would be able to find out how you got the result.
  • Venom737
    August 7, 2007 at 8:47 pm
    yeah, it works
    the only thing is you have to plan the scene carefully if you want them to interact in any way
    I use this a lot because I live far away from my friends so I make many movies about clones, where there are several me’s on-screen
  • Accountclosed
    August 8, 2007 at 5:28 am
    just for the background, i want to shoot a mac vs pc like commercial, and open with a master of 3 pcs and one mac.
    so while casting, i liked one guy for the pc who was about 6’5″ and a bunch of other guys between 5’8″ and 6′
    now i really want to use the big guy, but want all the guys to look about the same height.
    now when shooting on the greenscreen, do i need to change the height of the camera when shooting? i plan on shrinking the big guy to look like the other guys. thanks.
