Activity › Forums › Adobe After Effects › Greenscreen plate orbital rotation (noob question)
  • John Fishback
    June 9, 2024 at 2:57 am
    First, apply tracking marks to the green screen, so when you move the camera, the marks move with it. In post, track the marks then apply that tracking data to your plate. Before you make your final composite, using object removal, you need to remove the tracking marks from the green screen. There are many online tutorials that explain the process.
  • Haroun Al-shaater
    June 9, 2024 at 2:42 pm
    As simple as that? Sounds great thank you.
  • Graham Quince
    June 12, 2024 at 8:50 am
    I’ll just add that when you move the camera, make sure you go for largish translations, even if they are not in the final elements you use. Avoid zooms too. This gives the Camera Tracker more information and makes it easier for it to creeate a matching 3D camera.
