Activity › Forums › Apple Motion › greenscreen in motion?
Posted by Fred Estabrook on January 25, 2007 at 10:05 pmIs Shake really necessary or can Motion2 achieve acceptable greenscreen compositing with DV footage from a DVX100B?
Malcolm Thorpe replied 19 years, 7 months ago 3 Members · 4 Replies -
Arnie Schlissel
January 26, 2007 at 2:24 amHow well did you shoot the keys? If they’re well shot, you should be able to pull a good key in either Motion or Shake, if they’re poorly shot, you may not be able to easily pull a key in either.
I’ve been using Conduit from DV Garage in both Motion & FCP, it works very well in both programs with properly shot keys. For problematic shots, I’ve been Color correcting for the key in FCP, then exporting 2 tiff sequences, 1 with the CC & one without. The corrected key usually keys out very quickly, then you use that as a track matte for the uncorrected shot.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
Fred Estabrook
January 26, 2007 at 7:08 pmGreat information! Thanks for the suggestions. I purchased Shake (because it’s so inexpensive now – Apple won’t be selling or supporting it much longer) and I already have Motion2. I understand that proper green surface (we bought a 6×9′ fabric greenscreen), setup and lighting are absolutely essential for success (we haven’t shot the 5-min. clip yet)… the one thing I’m still debating is the plugin (I guess there are 2-3 good ones to choose from). Thanks again.
Arnie Schlissel
January 28, 2007 at 6:07 amThe same method of using a CC’d clip to pull the key & an uncorrected clip use for the foreground will work with Shake. I learned about it from a compositor who uses Illusion. I’ve found that it makes a huge difference. Some shots that were hell become very quick & easy to pull a key from.
Arnie
Malcolm Thorpe
February 2, 2007 at 6:11 pmWe just bought “dvMatte Blast” from dv Garage. A great plug in and almost drag and drop simple.
