Activity Forums Adobe Premiere Pro greenscreen help
  • greenscreen help
    Posted by Peter_student on October 3, 2006 at 12:21 pm
    When im keying a person onto a greenscreen i keep getting jagged edges around them- i’ve played with the settings but have had no luck- any tips/tutorials for getting rid of the jagged edges?
    Thanks in advance
    Peter_student replied 19 years, 10 months ago 5 Members · 5 Replies
  • Steven L. gotz
    October 3, 2006 at 1:43 pm
    Use a garbage matte to isolate the person as much as you can. Then use the chroma key filter. It helps to isolate the person so you don’t have to key out as wide a range of colors.
    Steven
    https://www.stevengotz.com
  • Tclark
    October 3, 2006 at 3:19 pm
    Try using progressive footage. If you need to, try deinterlacing. Progressive works best for keying. Also you can try a simple matte choker. Do you have After Effects? KeyLight is the best for Keying. There is a great tutorial from VideoCopilot.net. Under keying. Give it a look. It helped me a lot.
  • Sandra Miller
    October 3, 2006 at 6:54 pm
    Hi Peter!
    I’ve been having similar results. However, I have found that After Effects works best for keying.
    Good Luck!
    Sandra
  • Ponyack
    October 6, 2006 at 2:13 pm
    I have been using a stand alone App called Ultra by Serious Magic. It works like a charm. Probaly not the solution you were looking for but its an option that I recommend if you are going to be dong a bunch of key work.
    Otherwise, I would go with After Effects.
    Ponyack
  • Peter_student
    October 8, 2006 at 2:10 am
    Hey All!
    Thanks for your replies..I have tried ULTRA but i didn’t wana fork out the cash for it so i gave that a miss. I will give AE a try and see how I go. Thanks to everyone for the help
    cheers
