Activity › Forums › Apple Final Cut Pro › Greenscreen and Multicam
  • Greenscreen and Multicam
    Posted by Michel Bosma on January 20, 2016 at 8:37 am
    Hey Guy’s, what’s the best workflow for making a multicam clip with greenscreen footage.
    I have 2 camera’s both are greenscreen, do I first key them out export them an reimport the keyed footage for a multicam?
    Or do I just make a multicam of the original footage and then key them in the multicam clip?
    I’m asking this for obvious performance issue’s when using and a key and a multicam clip?
    Thanks in advance & greetings
    Michel
    Jeff Kirkland replied 10 years, 8 months ago 3 Members · 5 Replies
  • Jeremy Garchow
    January 20, 2016 at 4:24 pm
    When are you planning to do the final composite and what application will you be using for that?
  • Michel Bosma
    January 20, 2016 at 6:22 pm
    Hey Jeremy,
    I’m doing everything in FCPx so composite and keying all in FCPx
  • Jeremy Garchow
    January 20, 2016 at 6:27 pm
    I think it would be best to do each composite in the timeline, and not the multiclip, although it’s an interesting idea.
    Without knowing the specifics of the composite, I would imagine that would be the most flexible way to keep the composite looking its best.
    If the background remains the same for each angle, then I guess you could try and key each angle in the angle editor, but you’d have to finish the composite clip by clip in the timeline.
    Jeremy
  • Michel Bosma
    January 20, 2016 at 6:34 pm
    That’s what I thought to, I have a different background for every angle. So it would be best to key and composite them first and afterwards make a multicam of the exports. I think performance wise this would be the best option. And keeps me flexibel while switching in the multicam without forgetting to switch the background as well afterwards. If anybody knows a different way?
    Thanks Jeremy
  • Jeff Kirkland
    January 22, 2016 at 12:09 am
    That’s the workflow I’ve come to use. Key first, then create the multiclip, then edit. The nice thing is that if you need to re-key for any reason, you just need to replace the footage in the multiclip to update the edit.
    Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
    http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland
