Activity Forums Apple Final Cut Pro Legacy Green when rendering from motion
  • Green when rendering from motion
    Posted by Sarah Hollender on July 30, 2009 at 3:48 pm
    Hi everyone,
    I’m loving this site and want to thank anyone in advance for any assistance. I did look for an answer to this and can’t find it, although for some reason I think its something very simple I’m missing.
    I’m discovering motion for the first time, and have exported something onto my desktop and then imported it into final cut pro. A red bar goes up indicating I should render it, and before I render it if scan through the clip on the timeline I can see the image. When I render it, it plays back with the correct audio, but the entire picture is green.
    Could anyone please let me know how to resolve this or what I’m doing wrong.
    Phil Hollins replied 15 years, 10 months ago 6 Members · 9 Replies
  • 9 Replies
  • Matt Callac
    July 30, 2009 at 3:58 pm
    Is the entire screen solid green? or is it tinting everything green?
    i had a crazy green rendering problem in motion a couple years ago.
    In motion if you export using the same settings as your timeline in FCP is set to…you won’t need to render.
    -mattyc
  • Sarah Hollender
    July 30, 2009 at 4:09 pm
    It is actually two shades of green. Two completely solid rectangles.
  • Matt Callac
    July 30, 2009 at 4:23 pm
    never seen that before.
    try either
    Rendering your quicktime out of motion with the same settings that your fcp timeline is set to
    or
    Pulling the motion file directly onto the FCP timeline and rendering.
    -mattyc
  • Sarah Hollender
    July 30, 2009 at 4:38 pm
    Hi Matt –
    Right now it is saved on my desktop (out of motion) and I do drag it to the FCP timeline. When I scan through it, it seems like it will play fine. But then doesn’t when I render. I am just learning motion – so don’t know how to check the settings on that…but assumed that FCP would render it if I can see something when I go frame by frame on my timeline and can see it?
  • Matt Callac
    July 30, 2009 at 4:51 pm
    Are you talking about a quicktime file? or the actual motion procject?
    I’m slightly confused.
    In Motion Go into the edit menu and select project properties. Select whatever preset you need. ie…if you are working in FCP with NTSC DV footage…. Select the NTSC DV preset from the pulldown.
    If you are trying to Export a quicktime movie out of Motion. Then go to File>Export…. It should be defaulted to quicktime movie….click the option button next to it. Then from the Compression pulldonw menu select whatever compression type your working with in FCP…if you’re usind DV select DV. Then export.
    If you are tying to pull the motion file into FCP either import it in final cut…or while in motion grab the little file icon at the top of the porject file in the interface then hold cmnd (the apple key) and hit tab till you are back into fcp…then drop the file where you want it.
  • Ben Pirouet
    July 31, 2009 at 8:27 pm
    There are two reasons why i’ve had Motion exports in FCP go green on me
    1) The ‘Scratch Disk’ isn’t set up correctly or is low on space. Bizarrely occasionally when i’d had clips go green on me, just changing the Scratch Disk settings in ‘System Settings’ fixes that for me.
    2) The more common reason it’s happened to me is because in the project properties in ‘Motion’, the Bit Depth was set to 16 or 32 bit (float). Switching back to 8 bit usually cures that for me. When i first started using ‘Motion’ i assumed that the highest bit depth was obviously the best and would work the best. Not true 🙂
    Hope one of these helps 🙂
  • Theresa Bucci
    August 7, 2009 at 6:59 pm
    Have you figured out how to fix this problem? I think I am having the same problem with the green blocks as you.
    Every time I try to export my sequence from Final Cut Pro, every motion file I have turns into green blocks within the movie.
    This used to also happen when I rendered my video, but I changed settings and fixed it.
    tess
  • Thomas Frank
    November 3, 2010 at 11:20 am
    I also get the magic green effect.
    In my case only the imported footage turns green all elements that where made in Motion appear normal.
    But it only turns green when I use the Best Render option and appears to happen only with Apple ProRes footage.
    hmmm Apple own Codec does not work with Apple Motion???
  • Phil Hollins
    November 22, 2010 at 3:40 pm
    Having only just been inflicted with the green screen misery I tried both your suggestions but neither worked.
    My MacBook Pro at home doesn’t have the same problem. At work the only difference is that we have a BlackMagic video card.
    Eventually I took the last poster’s suggestion that it was Apple Pro Res that was at fault. So I changed the FCP Sequence settings’ codec to Photo JPEG. This solved the problem.
    It it very surprising that Apple’s own codec should not work with its own programs.
    MacPro 10.5.5
    FCS 2 (FCP 6.06 + Motion 3.02)
    BlackMagic Multibridge Pro
    MacBook Pro 2.16GHz Core Duo (not Core 2 Duo!)
    Same software
