Activity › Forums › Apple Final Cut Pro Legacy › Green symbol with check mark
Posted by Radhika on June 14, 2005 at 12:05 amwhat does it mean?
Radhika replied 21 years, 2 months ago 2 Members · 2 Replies -
Bret Williams
June 14, 2005 at 1:41 amIt means you accidentally hit ctrl+z and turned on the luma checking system. Just means that your levels are fine (on that frame). It’s up there in the menus somewhere. Just press ctrl+z again to turn it off. And just press it once. Not 3 times like you press the “post direct” button.
