Green Screen/Project Help
Hello,
I have been working on this huge project and I need to replace some green screen. I used FCP, Adobe After Effects, Compressor and DVD Studio Pro to create the project. If I put the raw footage that was filmed in front of a green screen directly onto a DVD it looks great (even on a big screen tv), but after I go though the different programs and replace the green screen the man sitting in front of the green screens face looks a little blurry or distorted, mainly around his eyes. If I watch the DVD on a computer in a small window it looks fine, but if I enlarge the window or watch it on a Big Screen TV it looks distorted again. I don’t understand why it looks fine before I replace the green screen, but not after. Do you have any idea how I can fix this problem? Could it be because of a setting that I have wrong? Is there a filter that could fix it?
Below are all the details of the project.
It was filmed in DV NTSC format and I assembled the entire project in FCP. Then I exported some of the green screen footage by going File, Export, Quicktime Movie. I set the settings to DV NTSC 48kHz, Video Only, No Markers. Then I put it in Adobe After Effects and applied some Keying and Color Correcting Filters which replaced the green screen. From there I exported it as a Quicktime Movie with the compression type set at DV/DVCPRO – NTSC, I have the frame rate at 29.97fps, quality set to high and the size set to NTSC 720 X 480 4:3.
Then I put it back into FCP to add some other video and audio to it and export the entire project as a Quicktime Movie with the same settings as before. Then I change it into a MPEG-2 file in Compressor, put it in DVD Studio Pro and Burn it onto a DVD.Any help is greatly appreciated.
Sloane
