Activity Forums Apple Final Cut Pro Legacy Green Screening silhouettes
  • Green Screening silhouettes
    Posted by Sue Lawson on November 11, 2007 at 9:22 pm
    Hi all!
    Apologies: I mistakenly posted this same query in the Motion Forum… (I’m assuming that this forum would be more appropriate).
    Anyway, here’s the situation: I’m sure that there’s a simple solution that I’m missing (due, I’m certain, to a serious lack of caffeine on my part)…
    1. the client has provided me with footage of an audience in front of a green screen
    2. he would like the audience (lit) to appear in silhouette (background will be keyed in)
    I can pull a decent key, but my mind is blanking on how to have the audience appear in silhouette (especially since they did not light the audience for this)
    BTW: I’m using FCP 5.1.4 with DV Matte Pro 1.5 — could also use Motion 2 (as I’m not as comfortable yet with After Effects or Shake)
    Any advice is greatly appreciated.
    — Sue
    Adam Smith replied 18 years, 9 months ago 5 Members · 8 Replies
  • 8 Replies
  • Aaron Neitz
    November 11, 2007 at 11:01 pm
    you could put a color corrector on it and turn all the levels down so everything goes black. ta da!
  • Jeremy Garchow
    November 12, 2007 at 12:07 am
    You can also use the alpha channel as a ‘travel matte’ on a black solid.
    Jeremy
  • David Roth weiss
    November 12, 2007 at 2:36 am
    I think Jeremy has the right idea, that is, if the client meant complete sillouette.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY™
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Sue Lawson
    November 13, 2007 at 4:05 am
    Thanks, Charlie.
    I’m probably missing something very basic, but if I turn all of the levels down so everything goes black, won’t that prohibit the use of the greenscreen in front of which they are seated? I mean wouldn’t that also make the green screen black in which case there would be no definition between the audience and the (now black) green screen?
    — Sue
  • Sue Lawson
    November 13, 2007 at 4:08 am
    Thanks for the response, Jeremy. So… I need to create an alpha channel just for the “audience” while maintaining the green screen in front of which they are seated?
    — Sue
  • Jeremy Garchow
    November 13, 2007 at 4:33 am
    No worries, Sue. Once you have pulled the key, your alpha channel has already been created and then you use that information to cut a hole in a layer above it.
    What you want to do is put your BG on track 1, your audience with your key pulled on track 2 and a slug or black color solid on track 3. Then control click on the track 3 and change the composite mode to “Travel Matte – Alpha”.
    Walter Biscardi explains this and other transparency methods very well in his tutorials here:
    Part 1:
    https://library.creativecow.net/articles/biscardi_walter/FCPTravelMat1.php
    Part 2:
    https://library.creativecow.net/articles/biscardi_walter/FCPTravelMat2.php
    Part3:
    https://library.creativecow.net/articles/biscardi_walter/FCPTravelMat3.php
    Hope this helps.
    Jeremy
  • Sue Lawson
    November 13, 2007 at 5:02 am
    Fabulous! Thanks a million, Jeremy!
    — Sue Lawson
  • Adam Smith
    November 14, 2007 at 7:19 am
    You’d need to do the key first and apply the levels adjustment to the results of the key.
    Video Photographer / Avid Editor / Final Cut Neophyte
