Activity Forums Apple Final Cut Pro Legacy Green Screen With Channel
  • Green Screen With Channel
    Posted by Martin Reuben on May 26, 2006 at 9:49 am
    I need to produce green screen footage that has an alpha channel for a large project. Over 200 scenes will have to be shot. Current software is FCP but I can’t figure out how to output the footage with the apha channel. Can this be done?
    Is there better software or a plug-in that will make this project flow a little better?
    Martin Reuben
    Martin Reuben
    http://www.trgstudios.com
    Walter Biscardi replied 20 years, 4 months ago 2 Members · 1 Reply
  • Walter Biscardi
    May 26, 2006 at 10:39 am
    FCP does not export with Alpha Channel. After Effects does.
    What you could do in FCP is simply export a Luma Mask of the shots by simply filling your key with white. The editor on the other end would simply use that mask to make the key.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
