Green screen while converting with FFMPEG
Hi everybody,
I’m using CentOS 5.5.
A friend asked me to install ffmpeg on his server, the problem is he already tried to install ffmpeg many times, from a few rpm repos, compiling from source, etc.. the result, a big mess, with lot of problems. Finally after a lot of work I solved the wrong ffmpeg installation and it was ok, however it seems there is some kind of misconfiguration (caused by them) that makes converted videos to show a green screen instead of the video content. Video shows a green screen, but the audio works well. This happens with all kind of conversions, avi to mpg, flv, etc.
Tried the same conversion on another ffmpeg server I have, and works well…
On the failing server, i see this while converting:[swscaler @ 0x1f86cb20] bad src image pointers
frame= 145 fps= 0 q=2.0 Lsize= 999kB time=5.76 bitrate=1420.2kbits/s dup=65 drop=0
video:804kB audio:176kB global headers:0kB muxing overhead 1.831160%
[root@s2232.warehouse235.info:~]And while running ffmpeg, shows this warning:
WARNING: library configuration mismatch
libavutil configuration: --enable-shared --prefix=/usr
libavcodec configuration: --enable-shared --prefix=/usr
libavformat configuration: --enable-shared --prefix=/usr
libavdevice configuration: --enable-shared --prefix=/usr
libavfilter configuration: --enable-shared --prefix=/usr
libswscale configuration: --enable-shared --prefix=/usrAny ideas about how to correct this?
Thanks a lot!
Steve.
