Activity › Forums › Adobe Premiere Pro › Green Screen smoothing
  • Green Screen smoothing
    Posted by Ryan on January 3, 2006 at 8:45 pm
    A few days ago i used a green screen for some interviews. I did my best for lighting, however, when i put it on premier it was choppy around the person in the shot. Is there a way to clean it up so it looks sharper??
    Jim Kanter replied 20 years, 8 months ago 3 Members · 2 Replies
  • Tim Kurkoski
    January 4, 2006 at 12:27 am
    Try using multiple instances of the Green Screen Key effect to pick out multiple ranges of color. You can add as many as you need.
  • Jim Kanter
    January 5, 2006 at 3:09 am
    If you shot on DV footage this can be a problem for any keyer.
    if you have After Effects check out dvMatte from dvgarage.com. it is optimized for Dv and does a terrific job.
