Activity Forums Panasonic Cameras green screen settings ?
  • green screen settings ?
    Posted by Arty Gold on December 1, 2007 at 8:23 pm
    hey guys and gals
    we have a green screen shoot this monday
    and this will be our first time with the hvx-200 (from the 100-b)
    so the question is of the 15 million different settings on the hvx
    what’s the perfered or best setting for green screen ?
    720-24
    720-60 ?
    another one
    thanks so much (once again-ha)
    Vince Becquiot replied 18 years, 9 months ago 5 Members · 5 Replies
  • Noah Kadner
    December 2, 2007 at 2:02 am
    I’d go 720p24pN Or 1080/24p. Test test test with the final workflow before you lock in a decision. More important than the camera settings are that the lighting of the screen is perfect and even- use a waveform monitor on set if you can.
    Noah
    Unlock the secrets of the DVX100, Apple Color and now the HVX200!
    https://www.callboxlive.com
  • Richard Harrington
    December 2, 2007 at 3:52 am
    Defintely true progressive
    Also get enough separation from Foreground to Background
  • Dean Sensui
    December 2, 2007 at 7:18 pm
    Here’s the settings I use:
    Video cam
    1080p30
    Detail level -7
    V Detail level -7 (both helps minimize edge artifacts)
    Detail coring 0
    Chroma level +2 (a bit more saturation helps the green channel)
    Gamma Low
    Knee Low
    Matrix Norm
    V Detail Freq Thin
    I’m using a green screen from EEFX.com and it’s exposed at 50 IRE.
    For software I’m using Primatte.
    Dean Sensui — Imagination Media Hawaii
  • Arty Gold
    December 3, 2007 at 2:39 am
    i also am using a firestore 100
    i’ve been shooting on quicktime setting
    if i switch over to true progressive do i than have to shoot on quicktime pN?
    or do i just keep my settings on 720 30p ?
    i think someone should get me a cheat sheet card !
    laminate too please ha
  • Vince Becquiot
    December 3, 2007 at 5:34 pm
    Not sure the settings matter that much as long as your are not overlighting, or underlighting out your background. Chroma boosting can actualy help, but I would worry about your talent(s) first. Primatte is in my mind as well for best software keyer I have used if you can throw 700 bucks at it.
    If you don’t have a scope (and your really should), you can use the zebra to make sure your screen is evenly lit. On a scope, I keep it around 50 IRE.
    Vince
