Activity › Forums › Sony Cameras › Green screen question
Posted by Jason Davenport on January 19, 2011 at 12:48 amWhen shooting green screen today the producer slash editor told me he always has trouble keying close to subject. And he was pointing out on the image (head shot)how there is a very small white line around the subject. I saw it as well. Just a guy in a blue shirt on green and there was a very very thin sort of outline around him. What is that?
EX-3, -3 db, 720 24p.Thanks,
Bo Skelmose replied 15 years, 8 months ago 5 Members · 9 Replies -
Brent Dunn
January 19, 2011 at 3:02 pmEach software may treat the information differently, along with correct lighting conditions, etc. It sounds like a halo effect. If you can find your feather settings, you should be able to fade it out. I’m just guessing here.
Brent Dunn
Owner / Director / Editor
DunnRight Films
DunnRight Video.com
Video Marketing Toolbox.netSony EX-1,
Canon 5D Mark II
Canon 7D
Mac Pro Tower, Quad Core,
with Final Cut StudioHP i7 Quad laptop
Adobe CS-5 Production Suite -
Jason Davenport
January 19, 2011 at 8:23 pmI’m sorry I didn’t say, but this is just looking at camera to monitor. Panasonic 1710. No post green.
Alan Okey
January 19, 2011 at 8:44 pmWhat’s your green background level, either in IRE units on a scope or in a percentage level on the camera’s histogram?
Alan Okey
January 19, 2011 at 9:34 pmIn the past I’ve come across “ringing” like what you’re describing when working with DVCPRO HD footage containing really hot green screens (80-90 IRE), but I haven’t seen what you’re describing when using an EX1 on a 50-70 IRE green background.
What else can you tell us about the lighting setup? Are you using particularly strong rim lights? Break down the lighting setup for us.
Jason Davenport
January 19, 2011 at 9:44 pmUnless it was being in 720 apposed 1080, he wanted 720. And image looks slightly softer.
As for lighting 2×4 Kino key w/opal, fill and vertical rim, 2×2 Kino. Green lite with 2 420’s LTM with 216 full flood. Green was a nice flat 50 ire. I’ll try to get a still later. -
John Sharaf
January 19, 2011 at 9:48 pmJason,
There are many types of keying software (and hardware). I’m told by several editors (I’m a cameraperson) that After Effects and Ultimate are the best, and from my own observations of keying sessions, there is a wide ranges of skilled technicians in this world, and I believe that is the ultimate determinant.
Finally, I’ve always lit my screens to be a stop under the key light in the foreground. This minimizes reflections too, and I’ve had very few complaints over the years.
JS
Bo Skelmose
January 19, 2011 at 10:27 pmHi
Remember always to have some backlite on the object – then you can get rid of the green reflection you will get on your object.A full pixel kamera like the EX will do better than DVCPro HD that have anamorfic compression 960×720.The EX are 1280×720
Tried the other day with my HPX2100 AVCIntra 100(10bit)/1280×720/50p/-1/100 shutter – Premiere CS5 and Ultra key – Fantastic – When the person moved around – as fast as possible – even brushing the hair – you could never see it was green screen. Not a sign of green – not anything that could tell.
Maybe just the lightning that did not mach the background – the biggest challenge with chromakeying. -
Bo Skelmose
January 19, 2011 at 10:34 pmJust noticed youre on 24P – cannot tell how it works on the panasonic monitor and when and if, it is converted to 25P or 30P.
This pull down thing might do things – any inputs on this ?
