Activity › Forums › Apple Final Cut Pro › Green Screen Problems with Final Cut Pro X
  • Green Screen Problems with Final Cut Pro X
    Posted by Jonathan Palmer on March 4, 2017 at 7:48 pm
    Hello All,
    I am working on a project and I’m having some challenges working in Final Cut Pro X.
    I have an image with a subject against a green screen. Unfortunately, the green screen and the subject were not properly lit and the image that I have is what I get… However, I am hoping to salvage the video.
    The problem in the video is when the subject waves his hand, there’s a trail of green that follows…
    Any ideas on how to fix this??
    Thank you!
    Kevin Rag replied 9 years, 6 months ago 4 Members · 4 Replies
  • Jeff Kirkland
    March 4, 2017 at 8:51 pm
    It’s a hard thing to fix but I’ve had success in hiding it with Hawaiki Keyer’s advanced edge tools. You could also try keying the hand seperately so you can be a bit more aggressive with the edges in that area while the motion is faster.
    Otherwise, you may have to resort to some roto work.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Lawrence Eaton
    March 4, 2017 at 9:02 pm
    Jeff,
    I agree with the Hawaiki option. Just bought it and it’s already been a lifesaver in a similar situation.
    Lawrence
  • Jonathan Palmer
    March 4, 2017 at 10:04 pm
    Jeff,
    Thank you! I’ll look into this. After posting and thinking about this problem, I ended up copying a clip from a previous, but similar project I worked on, and paste the attributes to the clip I was having some issues with. It fixed the problem!
    Funny how I struggled for days with this problem and after posting on this forum, I ended up finding a solution.
    Anyways, I’ll look into what you suggested as a just in case scenario for the future.
    Thanks a bunch you guys!!
  • Kevin Rag
    March 6, 2017 at 2:38 am
    Hawaii keyer is worth every penny you omy for it. Like others said, it has saved a lot of time and headaches for me:)
    Kannan Raghavan
    The Big Toad Films Pte. Ltd.
