Activity Forums Adobe After Effects Green Screen Noise
  • Green Screen Noise
    Posted by Faraz Mozafarian on January 14, 2011 at 10:28 pm
    Hello,
    I am shooting a pair of shorts on a green screen for a video I am making and am keying out the green using AE CS5 Keylight 1.2.
    The problem is I am getting a lot of noise on the shorts. I have messed around with clipping the blacks and have even creating a garbage mask as an alternative but am still getting a good amount of noise on the shorts.
    What is causing this? Any ideas?
    Faraz Mozafarian replied 15 years, 8 months ago 2 Members · 4 Replies
  • Faraz Mozafarian
    January 14, 2011 at 10:40 pm
    Here’s the image. I know it is not anywhere near perfect.
  • Kevin Camp
    January 14, 2011 at 10:41 pm
    it would be best if you could post an image that points out the noise, but if you’re talking about what i think you’re talking about, in the screen matte settings, set the replace method from soft color to hard color.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Faraz Mozafarian
    January 14, 2011 at 10:48 pm
    Kevin,
    It it is hard to see the noise in an image you can really only see it when I play back the video but your suggestions worked and the noise is gone. Thank You!
  • Faraz Mozafarian
    January 15, 2011 at 12:30 am
    Thanks for this post. Very helpful. Like I said I am new to this so any advice will greatly help.
    Just so you know I shot this with the Panasonic HPX170 720p 24p. Straight off the camera to FCP then imported into AE.
    Is there anything else I can do as far as compression?
