Activity Forums Adobe After Effects Green Screen Noise
  • Green Screen Noise
    Posted by Matthew Glasser on August 20, 2012 at 10:43 pm
    Editing a project that was shot in AVC-Intra 100 against a green screen. It’s just talking head interviews. I can get a good key using Keylight but I get a lot of noise in the face and clothing of the interview subjects. Noise is not an issue until I pull the key. Any suggestions?
    Barend Onneweer replied 14 years, 1 month ago 4 Members · 3 Replies
  • Tudor “ted” jelescu
    August 21, 2012 at 9:22 am
    Keylight may not give you initially the best results – you need to play around with it.
    Here’s a good tutorial:
    https://www.adobepress.com/articles/article.asp?p=1252172
    A simple Google search will bring some more good ones.
    Sometimes it is best if you transcode the footage to an uncompressed format and then pull the key.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Steve Brame
    August 21, 2012 at 1:06 pm
    Also, reducing the actual area of green that you are having to key out can be a big factor. To get the smallest area possible, this tutorial can’t be beat.
    https://library.creativecow.net/articles/rabinowitz_aharon/junk_mattes/video-tutorial
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
  • Barend Onneweer
    August 22, 2012 at 7:04 am
    And set Keylight to ‘intermediate results’ instead of ‘final’. This bypasses the spill removal in Keylight that’s known to amplify colour noise.
    You’ll then need remove the green spill using a Hue/Saturation filter or other spill killer.
    On the other end of things, it doesn’t hurt to remove noise before keying. Look into Neat Video, works wonders on reducing noise and compression artefacts which will dramatically improve the matte.
    Barend
    Raamw3rk – independent colourist and visual effects artist
