Activity Forums Adobe After Effects Green screen Music Video
  • Green screen Music Video
    Posted by Herminiocordido on September 21, 2007 at 4:47 pm
    Hi Guys.
    Planning on shooting a music video on 35 mm on green screen, i have access to a nice studio with big green screen.
    it is supposed to be a street party, so the backplate is a street, a parking or so.
    The camera will be always on a dolly, doing subtle but contant moves, so yellow track points on the greenscreen are needed.
    as i said we will be shooting 0n 35 mm and transfer it to 720p, .avi to get into After Effects and do every thing in there, (final output is sd dvd, but i love to have extra res to work with).
    I am the DOP, After Effects guy, so i will be hanged if this doesnt work.
    Basically i am thinking on creating the Backplate doing a 3d enviroment made up with stills (HDR), that i will take, so the dolly shots make sense.
    a lot of work to come, do you have any suggestions?
    Thanks a lot guys…keep up the good work
    H
    Steve Roberts replied 18 years, 11 months ago 5 Members · 6 Replies
  • Kevin Camp
    September 21, 2007 at 5:40 pm
    if your plan is to match a 3d comp camera to the greens, take a lot of notes on camera position and settings. things like distance to subject, disatnce to chroma wall, height of camera, the exact movement of the dolly (distance, and distance to/from subject or wall, you may actually want to plot each shot on a x,y grid), lens focal length, focal distance and i’m sure some others that i’m missing. that data will be important to get 3d layers, layered in space within ae to match movement and dof of your footage.
    it should probably be a pa’s job just to measure and record these notes for every shot.
    i think i would also try a test for creating the 3d scene and matching it to footage. it wouldn’t need to be greens, you could shoot on a brick wall, take notes, then try creating a scene and camera movement to match using a quicky garbage matte to mask the footage. it should be enough to test if your process will work, and/or what will need to change.
    when you shoot, think about what you’re going to track for the point of interest for your 3d camera (unless you shoot following a tracking dot, or your subject is standing still, you may have problems).
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Steve Roberts
    September 21, 2007 at 7:18 pm
    What app are you using for the 3D matchmoving?
  • Herminiocordido
    September 21, 2007 at 11:42 pm
    I have been looking into Voodoo, but not there yet 🙁
    H
  • Brendan Coots
    September 22, 2007 at 12:49 am
    My honest first recommendation would be to run out and buy Stu Maschwitz’ book The DV Rebel’s Guide. It is packed with useful info from the shoot to After Effects, specifically dealing with special effects, greenscreen etc. You will get a lot from that book, including all the needed camera measurements MoldyBoot mentioned.
    My second suggestion would be to do a complete test run using a DV camera just so that you can test your workflow and weed out any issues before shooting expensive film. This is almost mandatory unless you just really like living on the edge. Tracking dots (or even gaffer’s tape Xs) are pretty important, I would use yellow so that they can be keyed/roto’d a little easier but different folks prefer other colors. You should also really, really try to nail down the environment you will composite into the background BEFORE you shoot so you have some idea what type of lighting, and from what direction etc. you will light the live shoot.
    My third reco would be to consider very carefully your post process in terms of Codecs you will use, the pipeline, editing system etc. You will definitely want to stay in 10-bit to preserve the film’s latitude and retain high color sampling. Personally I would never do a project like this using AVI files, because it mostly limits you to Windows machines and certain codecs. There is no DVCPRO HD option, and the Video for Windows 10-bit implementation is sketchy (can truncate to 8-bit even though you THINK it’s a 10 bit file).
  • Rene Aguilar
    September 22, 2007 at 11:33 pm
    1st check the quality of the dolly or steady or mechanich arm. I have a terrorific experience with one arm that don’t make smooth movements… first I stabylize the shoot and later make the changes.
    2nd verify the size of your control marks (yellow spheres) this objects don’t gonna be tiny on the screen.
    And finally check the illumination on the scene (specialy on the green screen area).
    Have a good shot!
  • Steve Roberts
    September 23, 2007 at 2:32 pm
    … and get the book on Matchmoving by Tim Dobbert.
