Activity Forums Adobe After Effects Green Screen keying issue
  • Green Screen keying issue
    Posted by Matt Benepe on June 12, 2011 at 2:03 pm
    Just got some footage to work on for a quick turn around. It was shot on Red cam and the background is an even key, however they didn’t light the subject correctly so she’s filled with green bounce light. Obviously when I key out the screen most of her becomes semi transparent as well. I was trying to figure out the best way to deal with it.
    I tried using keylight and dispill bias on the skin, but it didn’t help much. I thought that I might be able to color correct afterwords to fix it. It wasn’t really working that well.
    Would using something like color range keyer work better in this instance?
    Any ideas?
    Thanks in advance
    Tudor “ted” jelescu replied 15 years, 2 months ago 3 Members · 4 Replies
  • Todd Kopriva
    June 12, 2011 at 3:54 pm
    It sounds like you’re trying to do the keying all in one pass.
    In general, you need to do keying like this in three passes, as described in this chapter from Mark Christiansen’s book.
    Then, after you’ve created the mattes, you can color-correct the subject to remove the color cast from the spill.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Tudor “ted” jelescu
    June 12, 2011 at 4:52 pm
    If what Todd recommended does not work, it may be that you need to roto, in which case Roto Brush can help, especially since you have RED footage with lots of detail.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Matt Benepe
    June 12, 2011 at 7:26 pm
    So i haven’t worked with Red footage before and was trying to import directly into AF to do the key. Once i got into some of the later clips I realized that I needed to go through the Red software instead. I did my color corrections and fixed the color casts, etc there and now i’m exporting to doing my key.
    Thanks for the suggestions too for the future.
    June 12, 2011 at 7:32 pm
    That would do it- glad you figured it out. For future reference, if you gave us more info, like importing RED straight in AE, then one of us might have caught it sooner.
    Tudor “Ted” Jelescu
    Senior VFX Artist
