Activity Forums Panasonic Cameras Green Screen HVX…
  • Green Screen HVX…
    Posted by Brandan Dennehy on August 24, 2008 at 6:25 pm
    I am a little turned around on one specific aspect of shooting for green screen. I understand I can turn my camera 90degrees to take advantage of the greater horizontal resolution. What I don’t get is, won’t that essentially reduce the size of my image on the CCD’s. I know I can set the framing of my camera to fill as much as possible but only within reason. It seems to me that I am I am loosing an awful lot of image. Does it actually make sense to flip the camera when the imagers are so small?
    Noah Kadner replied 18 years ago 3 Members · 2 Replies
  • Jeff Brown
    August 24, 2008 at 7:01 pm
    You would be taking advantage of greater vertical resolution, as you would be shooting in a “portrait” orientation. Typically used for a single person shot; humans are more often in a portrait orientation. And, the chip turns 90 deg. with the rest of the camera, so you’re still using the same area.
    -jeff
  • Noah Kadner
    August 27, 2008 at 8:29 pm
    Exactly- it works best with subjects that are tall and narrow and would gain additional frame area by re-orienting the camera vertically. For short and wide subjects stick with the standard orientation.
    -Noah
    My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color and Win a Free Letus Extreme.
    Now featuring the Sony EX1 Guidebook, DVD Studio Pro and Sound for Film and TV.
    https://www.callboxlive.com
